Tenor gateway disconnect tone settings
Grasmuis
Wilgeheuwel
Hi
We are using Quintum Tenor gateways with asterisk for our phones but can't get the gateway to recognize the telkom disconnect tone when a call ends, anyone here that know how to sort this out?
Impedance settings - 220+820 Ohm || 115nF
Enable Current Disconnect - Yes
Threshold - 100
Enable Tone Disconnect - Yes
Enable Polarity Reversal - No
Silence Timeout - 20
Enable Call Answer Supervision: No
Incoming Call Ring Timeout: 10
AC Termination Impedance - 31
Then there's also this:
South Africa has two zones - the North (old Transvaal, etc) use 400 Hz for 2.5 seconds, followed by silence for 0.5 seconds, repeated 4 times. The South (Cape) use 400 Hz for 0.5 followed by silence for 0.5, repeated as above. Essentially Telkom used different voice switches in the various regions
Thanks, will try this in the morning.
