FlyOnTheWall
- Dec 2, 2008
Will new router be fast enough
Apologies for these very basic questions, but I just want to make sure my ducks are in a row.
I just want to make sure I shouldn't be dividing by 10 somewhere....!???
I'm going to buy a new router, I mention the brand or ISP names just as examples. Thanks
Please correct me if I'm wrong.
The low end ADSL offerings in SA (from e.g. Axxess/ Webafrica) are all 1 Mbps or Mbit/s (not to be confused with byte = 8 x bits). So it's 1024Kbit/s or Kbps. (MBps is megabyte per second where Mbps is megabits per second.)
1. Modem routers like the Trendnet tew-658brm or D-Link 2750u have 10/100 base TX ports at the back (LAN ports i.e. fixed line). Does this therefore mean 10 or 100 mbit/s i.e. 10 or 100 times the low offering so it's more than ok?
2. Is wireless G (802.11g) therefore 54mbps i.e. 54 times the low offering, so it's more than ok if you're on the cheapest ADSL offering of the different companies?
3. The wireless N dongles and modem-routers offered are mostly have speeds of 150Mpbs or 300Mbps. Is this therefore 150 or 300 times the low offering, so it's more than ok?
(I don't really need to know about ADSL2+, but it seems it is 24Mbit/s whereas the older ADSL2 had 1.6Mbit/s or something. This is not an issue though since most modem routers sold seem to be ADSL2+ anyway.)
