Terrible Printer Woes --Please help
MidnightWizard
KZN
The trusty old Canon i850 decided to go on the blink ( seven blinks )
Turns out it needs a new PRINT-HEAD.
Stock is availble -- but at R760.00 -- at which price one might as well go and buy a new printer.
This is really terrible -- throw out an otherwise perfectly working printer just because of a bit of plastic with some fancy nozzles and some electronic contacts.
Well anyway what can one do -- so I go out and get a new Canon iP4700 ( new smart kid on the block )
Get it home set it all up put it on the Win2K machine-- set it up to be shared on the home network -- everything is looking good........
--WTF -- NO drivers for Win 98SE :(
( You install additional OS drivers on the host machine that is sharing the printer )
OK you say -- bloody silly luddite -- well ..... some of us hate throwing away old stuff that is working fine -- especially if you can put it on the network and make use of it.
So -- to cut a long painful story short.
Is there anyone here that fixes printers that might have a scrapped i850 that still has a working print-head for cash ?????? ( even if it is old )
or
Can anyone tell me if there is an equivalent printer for the iP4700 that had Win 98 SE drivers , drivers that WILL work with the iP4700 under Win 98SE
-- google is not taking me anywhere.
( Had a bunch of stuff installed under -- /spool/Drivers/w32x86 -- dll's etc Goes through the instal process -- but end up with an error message.
So much for "plug&play"
There is the fancy printer all dressed up and nowhere to go.
Much appreciate any assistance.
MW
You can try Partserv for a print head, but they can be a bit difficult selling to the public
Tel:( 031) 579 5853 / 5824
PartServe -- Nope
Thanks for the tip.
I am already with Partserv -- that is who I got the price from.
Incidentally -- I also contacted the guys that Partserv themselves get their stock from. ( British / European based company )
That is why I am looking for a used part from a scrapped printer.
I CANNOT pay R760.00 for some piece of plastic -- R250.00 is more my style :D
MW
Unfortunately printer manufacturers stick all the brains of their cheap printers into the drivers, that is why you are battling to get 98SE(obsolete!) operating with your printer.
This is why I prefer ethernet network printers and also check for linux support.
You can get a complete Lexmark e120n for not much more than that Crapanon's spare part.
