to key or not to key
Nickd
Started doing the kara key quest chain, got the first part of the key frag from murmur last night.
With such limited wow playing time it seems like i might just be too lazy to do the rest of it though... which feels really really nub to me.
i dunno =)
i'm pretty sure the palla is kara geared already.. but its SO lame to not have the key :P
gear advice pls:
cah-lick
meh, I wouldn't say you need to, but its good to know you can always get in yourself :) Especially when there are members of the opposing faction on their way and you're alone :p lol
Else there isn't really a need to. Just make sure there is someone with the key though :p
I would say get it. The instances required for it is pretty much standard to go to before you enter Kara anyway. Don't skip content just because you can. Going to kara in greens is doable within a good group, but it is a frustration to the rest of the raid.
You need it for the top/gatehouse. Sure someone else could open, but do you really want to always rely on someone else? Do you want to be THAT guy?
It's easy enough to get.
i dunno =)
gear advice pls:
cah-lick
http://be.imba.hu/ will give you a decent indication of whether or not your gear is ready for whichever type of PvE environment. You'll need at least a gearscore of 130 to do the 1st 2 bosses in Kara...after that you start spunging off the rest of the team.
I've been too lazy to do the key quest chain, luckily my 1337 rogue lockpicking skillz can unlock all the gates in kara :D
