Gabriella394
- Apr 1, 2016
Hey guys I want to to buy a smartphone my last one was a Huawei p8 lite but it's messed up and beyond repair. Hope I could get some advice thanks
According to the website your purchase includes a free cover. You can also buy a tempered glass screen protector from them for R149.25.Definitely going to go for the xiaomi mi 5 or mi 5s although I prefer black. Anyway do you know where I can find covers and screen protectors for mi 5 or mi 5 plus?
They are based in China so it takes a while to get here. Also, you may be charged import tax/duties by customs & no local warranty.How does Geekbuying work? i usually get products from TakeALot and it's in rands and I know the payment procedure. How does GeekBuying work i saw you can buy from a bunch of different currencies that kind of freaked me out.
Ask Scott for a quote - https://mybroadband.co.za/vb/showthread.php/867992-Imports-Scott-s-Shipping-ServicesOh **** thanks
Any other phones under R6000 that are in sa and wont need to be imported?
Need something with amazing battery life
I was looking at that but i heard the screen on time is only 5-6 hours
You'll struggle to find better than that mAh on other phones. Also depends on your usage and settings.
If you are serious about battery saving then you'll also be looking into rooting and modifying settings to maximise battery like underclocking and undervolting - Which is not possible on most mainstream phones nowadays.
