Globetrotter
A friend recently bought a Toshiba Sattelite Pro L100 laptop - yesterday it suddenly shut down without warning.
When I press the power button, the power and hard drive lights flash on, then shut off immediately (doesn't even last a second). The power light will also remain off until the reset button is pressed again, or you unplug the AC adaptor, then plug it back in. Every time I try to turn on the laptop by pressing the power button, the same process repeats itself, power light and h/drive light comes on, and then shuts off immediately after 1 second.
According to the user manual, if the laptop's internal temp becomes too high, the laptop will automatically enter Hibernation Mode or Standby Mode and shut down.
What's strange though, is that even if I leave the laptop switched off for an hour or three (therefore cooled off sufficiently), then it does the exact same thing when I try to switch it on again (shuts down after 1 second).
The laptop never appeared to physically overheat, so I'm surprised that overheating is the cause of this problem? (Please note that the laptop is only 2 months old and therefore should be quite clean of dust)
What should I do? Any suggestions?
How do I rectify the problem? I have not been able to switch on the laptop successfully since.
