savagezaing
- May 14, 2008
I recently bought the TD-W8970 from takealot. I was a little confused when it arrived because they seem to have changed the product from a 3 antenna(V1) to 2 antenna configuration (V3) and some other changes between versions. And I seemed to catch it in the crossover.
My problem is that I have a "Busy" house :
2 Cellphones
3 PCs/Laptops
TV, NAS, Wii, Chromecast and PI mediaserver
The cellphones and 2 laptops leave the network at various times during the day.
What happens is that my internet would work perfectly stable until a "new" device is turned on eg. I come home and switch on my laptop and connect to the wi-fi. At this stage the internet just stops working and the quickest way to "fix" it is to back-off with the newest device. Then the Router does its thing and reconnects after a minute or so. And the process repeats itself when I reconnect the device again.
Does anybody else have the same experience? Aka flaw in router or is it just my specific router is the problem.
I can also mention that it's not the wi-fi that breaks the network, my Pi was the newest device for a long time and unplugging it was the solution.
2 Cellphones
3 PCs/Laptops
