TrueTenacity
My docker server went haywire and I though it's been a year and a half since I set it up, I'll re-do the whole server while trying to fix it.
I've followed the guide and everything is setup and working locally but absolutely nothing works the moment I try to access anything via my domain.
Traefik is setup and working locally, the ports are option (I've even turned off *ALL* the firewalls to see if it was that) and nothing gets through...
It worked perfectly when I set it up the same way last time, but now everything, including the traceroutes just timeout.
Tracing route to dannyb8.ip.afrihost.co.za [102.182.106.127]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms RT-AX58U.local [10.0.0.1]
2 3 ms 1 ms 1 ms 100.98.84.1
3 * * * Request timed out.
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
Trace complete.
