Transmission fluid
alpine
Can i get this @ any filling up station, my gears are freakn too stiff:eek:
Take your car to a mechanic
If your second gear is the problem your gearbox is on it's way out. Best to have it checked by a specialist ;)
Its probably my clutch(can barely feel the damn thing anyway), ill get a new clutch plate later for now cosmetic stuff will do
Check the clutch cable too, usually it needs to be adjusted.
My gears were getting stiff, the mechanic changed the tension on the clutch cable and all was working great again. They usually do this for free, so try it first :)
will do, do u know if steves autoclinic is any gud??
Manual transmission barely ever needs transmission fluid. I suspect it's the clutch if gears are scraping. Steve's Auto, not too bad...
SAC is the worst place on earth to take your car IMHO. What kind of car is it?
