Breaker187
Hi everyone
Seem to have a problem adding additional remotes to my garage door.
The controller bit is the first pic and the remotes are in the second pic.
Now I've used the jumper to go in to program mode, but for some reason the light blue/new remote will not pick up, if I "reprogramme" the older dark remote, it picks up.
Steps I followed to program/add a remote:
Put jumper on the "P"
Hold button of remote.
Additionally the light blue remotes one red button is programmed to my sliding gate with an identicall looking E.T. Controller.
So, is it that the garage controller is outdated and can not be used with the newer light blue remote ie get a new controller for the garage, or is there something else that I can try? Any advise before I reset the whole thing with jumpers accross all the pins?
TIA
TIA
