The_Unbeliever
Normally this problem is not a biggie.
But it is when the PC uses UEFI.
This causes most Linux distros not to see the C: partition (when you use an offline password change utility).
And the local administrator account is disabled.
And the guest account is disabled as well.
And booting from the install CD to run a command prompt from the repair option doesn't work as the installer says that the target windows version is totally different from the version being run from the CD... (this is for a registry edit to re-enable the local admin account)... for both the 32-bit and 64-bit version...
Lovely.
In the end, the solution is so simple, it is laughable.
Disconnect the network cable, boot the PC up, login, re-enable local admin account, reboot, log in as local admin, reconnect network cable, rejoin domain, and you're all set.
Fun.
Lovely.
Fun.
