Tucson Clutch replacement.
Opel177
So my releaser bearing is squelling when press and release the clutch. To change the bearing alone is stupid since I feel a slight shudder on take off and change down from 3 to 2. I will do the complete clutch kit. My question is which brand do I fit, LUK is 4300 and Valeo is 1400. I have a 2l petrol fwd. A clutch specialist said LUK is the best whereas Valeo might give u a problem but Valeo is Oem so.....
What should I do?
LUK is the Boss, never take chances on a clutch, it's expensive to fit and you want to do it right, first time. The price for LUK is slightly high but the price for the Valeo is suspiciously low, shop around and see if you cannot get it lower, there are also other good brands like Sachs.
