TV boxes and DSTV Now with Telkom LIT
BeRt21
Hi all.
Does anyone here have a telkom LIT box running dstv now? Have you experienced issues with dstv now and google certification this last week?
I have a mecool pro L running android tv and has widevine L1 as well as a H96 pro + running normal android and both having issues. I have figured out a work around but its a pain.
Does the telkom lit box support dstv now from playstore and are people also having the same issues?
Works perfectly fine on the LIT box. It's available from the playstore. Certified box recognised by Google as well as MultiChoice.
If your device is not certified, you will keep having to 'clear data' from your DStv app from time to time as it will keep giving the error of the device being uncertified.
Hi all.
how did u figured out plzz im stuck too my box not authorized bcz its rooted
