TV mount - standing mount needed
shadow_man
I've got an old Victorian house and the walls are of old clay brick. I've hung things and had them fall off or down. Thus I don't want to risk the tv falling and breaking. I'd like to get a standing mount that I can seat on my desk / table.
Any ideas in CT?
Any ideas in CT?
How big is the TV?
I've bought 3 tv's in the past and all 3 came with "standing mounts" Find it rather odd that you dont have one, unless you bought it secondhand?
Not really sure how one would go about getting that specific item as all brands/models have their own specific design for that particular tv.
I've got a PC with 2x Cinema Displays on the desk and no space for the TV. If I mount the TV on the wall it will fall down.
Hence I want a stand that the TV can stand on and be higher than its default plastic base allows.
So something like this that can sit behind the 2x monitors, but be height adjustable so that I can see the TV above the monitors.
REMEMBER I CANNOT WALL MOUNT!
http://img.ebyrcdn.net/48273-271354-800.jpg
