ScottulusMaximus
So I've got a UniFi 6 Long-Range Access Point en-route to upgrade my network just a tad and I am super confused about POE, seems a complete mess...
AP: https://store.ui.com/collections/un...ints/products/unifi-6-long-range-access-point
POE Injector: https://store.ui.com/collections/operator-accessories/products/poe-injector-50v-60w-airfiber-poe
Router: https://store.ui.com/collections/operator-edgemax-routers/products/edgerouter-x
I got that injector because it was the only one I could find that could do 20W+ at 48V
Setup will be router>injector>AP, this shouldn't blow anything up right? Spec sheet says the AP can do "Supported Voltage Range 44 to 57VDC "
And I can't go injector>router>AP because the edgrerouter is only 24V right?
And why oh why are there so many damn POE specs, AFAIK you've got passive 24/48V and then "af" and "at" and PoE++?
