I seem to have really bad luck re sound cards, see my previous thread -> http://mybroadband.co.za/vb/showthread.php?t=200158
I got myself a new graphics card today, Asus EN9600GT, which I plugged into my PCI-E slot and then moved my sound card down a slot. It was all working fine until I tested a HD youtube video. There was a sudden loud screeching beep and the computer froze. I restarted and my sound stopped working, not only that but it doesn't actually pick up my sound card anymore.
I have 3 PCI slots but can only use 1 since the graphics card takes up all the space so I can't really test it in another slot.
I'm running Ubuntu Karmic and these are some outputs from when the card was working:
lspci -v
aplay -L
lspci -v
Code:
03:00.0 Multimedia audio controller: Creative Labs SB0400 Audigy2 Value
Subsystem: Creative Labs Device 1021
Flags: bus master, medium devsel, latency 32, IRQ 20
I/O ports at d000 [size=64]
Capabilities: <access denied>
Kernel driver in use: EMU10K1_Audigy
Kernel modules: snd-emu10k1
aplay -L
Code:
front:CARD=Audigy2,DEV=0
SB Audigy 4 [SB0610], ADC Capture/Standard PCM Playback
Front speakers
rear:CARD=Audigy2,DEV=0
Rear speakers
center_lfe:CARD=Audigy2,DEV=0
Center and Subwoofer speakers
side:CARD=Audigy2,DEV=0
Side speakers
surround40:CARD=Audigy2,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Audigy2,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Audigy2,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Audigy2,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Audigy2,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Audigy2,DEV=0
IEC958 (S/PDIF) Digital Audio Output
null
Discard all samples (playback) or generate zero samples (capture)
pulse
Playback/recording through the PulseAudio sound server
