UHS-I Speed Grade 3 rating microSD
marine1
A black hole in the universe - JHB
Hi guys I need a 128gig UHS-I Speed Grade 3 rating microSD, for a drone,
Which would you recommend, there seems to be a lot of specs and tech information one needs to understand about cards,
This is the spec the drone needs to run correctly.
Any advice which card to get on Takealot maybe?
This is what I use
I also have 64gb Extreme (not the pro) which I use in my GoPro hero 8. Both have performed well but I'd recommend the Extreme Pro if you can fork out a little extra
I have a 256GB one for R700 if you're interested.
