Unbranded b683 firmware
ghs88
I have recently bought a Huawei b683 from ebay. It seems that I was flashed with a branded firmware (mobily or something) can I unlock it or at least find an unbranded firmware and flash it again?
Most of these modems/routers are branded in some way - Even if it's just network parameters.
The B960 & B970 both have their settings changed by uploading a 'custom' file. I would assume your device is much the same.
Sadly, none of my regular file sources have anything listed for the B683 which makes more wonder if it is not just a re-packaged version of an existing device...
Is it locked? Does it see a network signal with a RSA SIM inserted?
In theory it should connect to a PC via the USB port but some foreign networks have the modem shipped with the port disabled!
If you can find out the firmware version then I'll try to see if it is similar to any other existing device...
RE:
Hi,
I think I have the same problem..
this is my modem info:
Modem Software Version:
1146.11.994.12.111
Modem Hardware Version:
WL1B683M001
Device Name:
B683
Router Hardware Version:
WL1B683I001
Router Software Version:
1146.11.47.01.109
and it doesn't see the network signal except with the original SIM card that came with it..
Thanks for Firmware but remember this Firmware will not UNLOCK your Router.
