I am battling with an unstable connection. It will work perfectly for three days, and then suddenly the line disconnects every 30 minutes or even worse. With Cybersmart, and their connection logs say "User-Request". Even if I unplug the telephone cable - which should be "Port-Error"?
The line had been fine for years, and then suddenly end of August everything went pear shaped.
Tried everything so far - another router, changed all the cables, changed the pots filter, made sure there is nothing else connected to the telephone line, even removed the "surge arrestors" from withing the telephone plugs. No luck.
Interestingly I can make the downstream SNR go up if I make a phone call - it goes up by about "2" units. During times of instability the SNR appears to be fluctuating wildly up and down - down to below 6 and then it is game over.
It takes Telkom 3 weeks to come out, and then they say there is nothing wrong with my line. Aaargh.
Allegedly I am with this exchange: http://www.broadbandstats.co.za/exchange/WTYG
Not sure what else I can do but cry.
