Vaughankzn
- Nov 1, 2011
Hi Guys,
Some questions concerning fixed wireless & Rain LTE-A
1. If you not using the router during the day ( at work ) do any of your turn off the router & only have it on when you home ?
2. How can you tell if getting LTE-A etc , if run a speed test is that confirm it ?
3.Can you only check on the Afrihost site concerning how much data you used ?
4. Can I connect the my Huawei B618 to my spare Router ( TP-Link ) because it has more Land points . I have Network cables running to TV etc.
