Upgrade power supply?
emile124
I am buying a new pc and i I'm going to put it into my old case with a 410W Thermaltake power supply.
New specs:
3ghz core 2 duo
geforce 8800 GT
320gb hard drive
4gig ram
I haven't really budgeted for a new power supply now. I know 410W is not optimal, but will it give me problems or should it be OK for a while.
Thanks.
Without your graphics card this setup will use around ~250W max (calculated by a PSU calculator) and even with the graphics card will come to below the PSU's ability, but I do recommend that you not drive your computer hard. A 410W PSU (correct me if I'm wrong) supplies around 350W of constant power with a startup peak of 410W.
The recommended power on the box of my 8800GT says minimum 500W .... so /me went and made sure I had at least that :o Rather safe than sorry .... sell your current one and get a cheap 550W maybe?
Ok thanks. If I have to upgrade now what would be the cheapest option for about a 550W PSU?
Probably between R400 and R600 depending on where you look :D
I disagree. That thermaltake isn't great at all but it wil be better than those cheap 500w out there. Stay away from the el' cheapo PSU's
6 PC's down the line (all with el cheapo's) and not one power prob ......... Tis just a marketing ploy I tell you ;)
The things thats going to eat the most of your watts is that graphics card and processor ,so just
goolge for a review on your 88gt and processor normally they tell u how much power the device use under reviews.Form there u can work it out.
Thanks.
The 8800GT uses about 230W of power when under stress. (Playing games). Would recommend a 450W or 500W just to be safe. :)
On my PSU box it says that it's peak is 500W. Would that mean that i have at least 410W constant power?
Then u should be fine.
By the by, most reviews test the entire system under stress and idling...
and i remember a 8800GT under stress was under 300watts...dunno how accurate they are though.
http://techreport.com/articles.x/13479/7
That makes me wonder though, why would people need 550watt+ psu's when most reviews state the power draws of top end cards + system hardly passing 300?
