It depends.
If you have a smart LNB (which uses a single cable from the dish/LNB to the decoder then you're safe.)
Not sure if the old Explora used twin LNB (which requires 2 cables to the decoder) then you either need to change to the smart LNB or get a multiswitch.
That LNB is properly cooked.. I would replace that soonIt seems to be a single cable.
But I will phone dstv later to confirm.
Update: confirmed I do not need to replace the LNB.
Got here searching smart LNB.
Workers have a dish with this LNR.
What LNB can I put in there to run 2 OpenView decoders from?
