So i put in a request to upgrade from 384K to 4096K, with telkom, how long does it take to be re-synced? Does a Technician have to actually go to the exchange and change it physically, or is it merely a software switch?
Hmmm, Well I will shoot home at lunchtime and check if it's been done yet!
I'll be so stoked if it has!
Actually, no, what it's doing is normal:
http://mybroadband.co.za/news/adsl/12725-ADSL-uncapped-after-hours-for-R295.html
You're throttled to 384kbps during office hours then 4mbps after-hours. Your line upgrade has been completed![]()
does anyone know if you can check online if the upgrade has occured? like in the telkom client portal?
They don't change the line connections speed only telkom can do that you will just be throttled during the day your modem will still say connected at 4096
I upgraded my line to 4meg a while ago and it took a few days so just keep calling them and asking them what the status and escilate if possible you will eventually be upspead
No, but accounts can be limited to X speed, and the connection, while performing the handshake for PPPoE, can indicate what speeds (up/down) it's able to run at, if I'm not mistaken.
That would be the indicator for him on his router where the router claims it can achieve in excess of 4mbps down, 1.5mbps up, but his actual connection (the running account, perhaps?) is only 384kbps down, 127kbps up (127kbps according to his router, not me).
In any event, his line looks to be upgraded to 4mbit already.
