Upload Speed
Diesal
Diep River, Cape Town
Why is it that some people have an upload speed of 640000 and others 512000? How do I get the 640000 one?
and on Telkom's website it says:
TELKOM.CO.ZA said:
Up stream line sync speed:
minimum 256kbps, maximum 512kbps.
or am I mistaken?
yes, think so
512000 = 48.8 kilobytes per a second
640000 = 62.5 kilobytes per a second
I guess if you got the 640kbps rate, then you're just lucky.
When a friend of mine had ADSL issues, I saw that his line was synchronizing at 640kbps down, 192kbps up. We phoned the Call Centre asking to reset the port, since I thought the wrong rates could've caused the frequent (like once every 2 seconds) disconnects. After they reset the port, his speed was down to 512kbps again and it didn't even make a difference w.r.t. the disconnects :( If I just knew that it wouldn't make a difference, my friend would've still had 640kbps down...
