I've recently had a number of power cuts where I live, the power went out five times last night, for example.
This is going to murder my PC, so can you guys recommend a UPS? I'm a little worried about the transfer times from AC to battery for the cheaper models (though I know very little about UPSs). I don't need the the UPS to run the machine for several hours if the power drops, but I want enough time to be able to shut down properly.
My power supply is a CoolerMaster RS550-ACAAE3 GX 550W.
Other specs:
Intel Core i5-2500K
Biostar TZ68A+ LGA1155
1 TB HDD
8 gig RAM
Budget? Low, but I don't want to buy something for, say, R400 and it turns out to be useless.
Thanks in advance.
Other specs:
Intel Core i5-2500K
1 TB HDD
8 gig RAM
Thanks in advance.
