UPS capacity
Nostrebor
centurion
What are the chances I can use a larger battery on my old 600VA UPS than the 7.0 Ah fitted at factory ?
You can use a bigger battery within reason. The electrics will handle it just fine.
What you might not be able to do is fit it inside the UPS. There's a thread somewhere here where forumites had modded a slightly bigger UPS but with deep cycle batteries on the outside.
Thank you. Exactly what I had in mind ! Will eventually report back.
This is the one I think:
