LLoydizle
Hey everyone!
I bought a UPS for loadshedding to keep my fibre connection up.
Problem is, I keep getting disconnects (they last for less than a second). I tried everything to find out where the issue is and it all led to the UPS. When the router and ONT are connected to the main powerline, everything works fine. This also happened on two different UPS.
The first one I tried was this: https://www.takealot.com/rechargeab...or-internet-routers-cctv-smart-d/PLID72925744
The second one is: https://www.computermania.co.za/gizzu-60w-65wh-17600mah-mini-poe-dc-ups-black.html
Both the Router and ONT require a 12V connection, so I made sure that the UPS is set to that as well. I do also keep the router and ONT plugged into the UPS as well and the UPS itself remains plugged into my mains.
I'm not sure how to fix this? All help will be appreciated!
Thanks!
Thanks!
