Ups fan wont stop running
veez9999
Hi guys, just got my Gizzu GPS300 300W. Works like a dream. Only problem is the fan wont stop running. Its only a week old. Any ideas?
Charging Times:
-AC Adapter: 18V/3A (6.5hrs)
That's probably because it's basically always charging. With so much load shedding it likely never gets to fully charge properly.
It's a small UPS 300W. See pic
The device is recommended to be used as a Power Station; not as an always-on, pass-through solution. It is not recommended to use the device while charging or to leave it constantly plugged into the mains, as this can cause battery degradation.
No guys, I think this thing imhas some kind of fault. I left it unplugged all night outside in the cold. This morning, the fan is still running. I have asked for a return.
You're aware that most ups can require 12 hours of uninterrupted power to charge
