UPS - Matrix Warehouse
Aharon
Hi,
Saw well-priced UPS's at Matrix and they say on the box they have a USB interface. They were their brand - Zixxa (sp)
Anyone have experience with these?
The USB was the attraction for me, but don't want more junk - last one lasted 3 months.
I bought a Proline 650VA UPS a couple of years ago and it is utterly useless. Often it won't switch fast enough from AC power to battery power, which would cause my PC to switch off and then on again!
I simply had enough of it and bought an APC UPS instead and so far I've been very impressed with it, but it was very expensive as well.
The Powercom Black Knight Pro is pretty much the only other UPS that I can recommend, other than the APC units.
Eaton is pretty good as well. They are not all bad, some good brands out there besides APC like Tripp Lite, Powervar etc
Personally, I wouldn't recommend the Powercom BNK Pro.
The resellers locally sell the ~220VAC version which isn't fit for SA use. We use ~230VAC here which goes up to ~240VAC, that causes the UPS to step down the voltage to ~205VAC. That will put significant strain on the PSU. So if you don't mind constantly replacing your PSU, then get the BNK Pro.
Not to mention that it doesn't output true sine wave (it outputs "modified sine" aka stepped square wave).
In fact, just about all PSUs sold today use power factor correction which is ONLY compatible with true sine wave output. Anything else will significantly shorten it's life. So any UPS that doesn't output sine wave can at best be used to quickly shut down (even though that already causes significant heating in the PFC circuit). It even sounds dodgy. The PSU makes loud noises as it vibrates at the stepped frequency range.
Buy a decent PSU or just forget about buying one.
my 2c.
Thanks Gnome. I'll take that in consideration when making suggestions for UPS' next time.
I haven't bought a Powercom UPS before, but people on Prophecy Forums suggested/recommended it, and clearly they had no electrical expertise.
The ones from Matrix are about as good as what you will find at other computer shops. In my experience ALL the UPS devices I have used have lasted about a year. maybe it is the nature of the device, but maybe somebody can tell us if you can find better than this?
BTW, I'm using two of these Zixaa's from Matrix and so far so good. The USB interface and software works as it should.
Thanks Gary. Gnome - what would you recommend at an affordable price?
Well let me explain it like this:
A computer PSU doesn't work well in under volt situations (you can Google and confirm for yourself). Under volt being less than ~110VAC or ~220VAC.
Powercom Black Knight Pro would have been the economic choice, but because it is a 220VAC model you will run your PSU at prolonged under voltage. When I tested here at home the UPS spent about 40-50% of a day running at ~205VAC and the rest at the standard ~230-234VAC from the socket. That is very bad!
Similarly if a UPS isn't sine wave and any of the PSUs have power factor correction the components start vibrating which causes them to heat up (and thus significantly shortens their life as well as causes a loud humming noise).
So to answer your question:
If you don't mind constantly replacing the PSU (and possible the UPS), then buy something cheap.
If you don't mind spending money once, then buy APC SmartUPS (cheapest when I did my research).
If you don't have the money for a UPS you can always buy an APC power conditioner (if that is what you are worried about) but you won't have backup capabilities.
