will_i_a_m
- Jun 27, 2011
Hi.
I bought a UPS to connect my fibre router and ONT box to continue working while load shedding is going on. The UPS adapter of the power cable doesn’t fit into the ONT power port. There’s a proper plug and a small hole at the back. I’m not even sure that the small hole is a power port. The ONT looks like this:
The adapters that run from the UPS, but doesnt fit the small hole of the ONT is circled with blue, look like this:
Does anyone have advice?
The UPS is a GIZZU Mini 8800mAh Dual Voltage DC UPS purchased from Take a Lot. In hindsight, I’ve realized that the UPS is not big enough for the ONT - if it can even be placed on a UPS. I will get a bigger one if I can manage to connect the ONT to the UPS. The ONT unit belongs to Frogfoot and according to them the ONT is only compatible with an inverter.
I hope someone can possibly help me (shed some light haha).
Back of the ONT:
ONT power adapter:
Back of the ONT:
ONT power adapter:
