It depends on the capacity of the batteries in the UPS.Hi Guys
I am thinking of getting a 2KVA UPS. How much uptime will it give me? I have the following devices.
-6 x W6 Unifi lite - 12W max
- 2 x Netgear Switches - 6W
-1 x Huawei router - not sure, maybe 12W
Kitty
lolIt depends on the capacity of the batteries in the UPS.
I would rather recommend a 2400W inverter with a 2x 100AH batteries, that could last 24-36 hours without damaging the batteries.
A normal 2000W UPS would last about an hour. A UPS is not designed for long uptime, it's just so you can safely shutdown your PC or until the generator kicks in.
Not necessarily, I'm running my bedroom 9v 0.6amp router through a 650va UPS and it happily does 2 hours, which then auto shuts off, so 15 to 30 minutes before load shedding endsIt depends on the capacity of the batteries in the UPS.
I went according to my 2000VA Eaton datasheet, it says 100w has a runtime of 1Hour.Not necessarily, I'm running my bedroom 9v 0.6amp router through a 650va UPS and it happily does 2 hours, which then auto shuts off, so 15 to 30 minutes before load shedding ends
That's roughly 100 Watts, about the same as my lounge setup for loadsheddingHi Guys
Kitty
Did you already buy it?Is there a way to turn off the beeping sound on the UPS when power goes down ?
noDid you already buy it?
Yes, open it up and stick a big fat piece of Prestik on the piezo tweeter speaker, it will muffle about 85% of the sound, enough for it to be bearable, like having a conversation with @46FemaleIs there a way to turn off the beeping sound on the UPS when power goes down ?
I enjoy hearing the beeps faintly as it reminds me everything is working properly.I have an Eaton 5E. I have to use the app on pc to silence it but then when the ups goes off the settings revert back to default.
Alternatively you can open it up and rip out the part that beeps
