UPS v Inverter?
Fratpacker9
pretoria
Hi, I am a university student, and I have upcoming exams in June. The problem is that these exams will be held remotely online due to lockdown restrictions. So, I've been searching for a suitable UPS for these exams in case I get to experience a loadshedding during my exams. However, now someone tells me a UPS would not last to power up my desktop for the duration of the exam (which is 3 hours), and that I should be searching to buy an inverter instead. I wonder if this is true?
Can you guys help me understand the specs, and the difference between an inverter and a UPS? Which one should be suitable in keeping a desktop on for an exam?
Thank you.
See 2 articles below and then some links to products that may be appropriate.
A long run UPS but, they cost as much or more than an inverter and would not have near the capacity or life span of an inverter..
Would work well..
Thank you.
Well if you can afford an inverter which is expensive, maybe consider buying a laptop that gives you 8 hours plus.
Apart from the laptop if you go that route , make sure you have something to keep your net connection up, and if you can also have an internet connection backup plan
How much would such a laptop be?
Depends on his requirements, i.e more powerful requires bigger battery, more expensive. Since I dont know what his requirements are, it is hard to say.
For example using Amazon as it is the quickest search:
Further down:
Battery Technology has come a long way.
strictly speaking a home use UPS is intended to allow you enough time to save your work and shutdown your PC but it will not power the computer for very long once the mains power is gone because the battery is quite small.
An inverter will generally be connected to a battery and change the battery DC power into AC power. The capacity of the battery will be one of the factors that determine how long it will provide power (the other is the size of the load - i.e. how much power the things that you plug in use).
Many people use the term UPS when actually meaning "backup power" but a UPS is to some extent also actually an inverter - so do not worry too much about the actual name just try and make sure it will provide power for as long as you need. For 3 hour desktop and monitor use an inverter and battery will likely be cheaper than a single purpose UPS.
A laptop could give you more bang for your buck depending on what is most required. If only needing to get through one or two exams and loadshedding causes no other issues then money for a laptop seems a good option. An inverter and battery can be used to power other things even when not doing exams.
Check with your academic department what happens if the internet connection goes down - even if you have all the backup power needed for computers and routers and what have you, not all connections remain on/stable during loadshedding.
@Fratpacker09 what he said.
