Some whacky Wednesday sh*t
forums.cpanel.net
MariaDB published an update on November 5th, 2019 that can cause MariaDB to fail upon startup on cPanel & WHM servers. We've identified this as an upstream issue with MariaDB (MDEV-19073) affecting the following MariaDB versions:
10.1.42
10.2.28
10.3.19
10.4.9
The following error message is visible in the MariaDB startup output on affected systems:
The only known workaround at this time is to perform a downgrade of the MariaDB RPM packages. While there are no supported methods of downgrading MariaDB using cPanel & WHM, you or your system administrator can manually perform this downgrade using the following command:
yum downgrade MariaDB-server MariaDB-common MariaDB-shared MariaDB-client MariaDB-compat MariaDB-devel
Known Issues Status Page - cPanel version 84
Known Issues Status Page This thread includes status updates for known technical issues. Reminder: cPanel & WHM version 84 was introduced to the RELEASE update tier on 2019.10.29. Please reply to this thread if you encounter technical issues after updating your server to this version. You can...
10.1.42
10.2.28
10.3.19
10.4.9
MariaDB is aware of the issue and working to solve it. We'll update this post with more information on the status of MariaDB case MDEV-19073 as it becomes available.InnoDB: Failing assertion: table->can_be_evicted
