URGENT - Replacement external power supplies.
CodeMaster
Does anyone know where I can purchase a replacement power supply for our network switch? It is the standard two-pin adaptor with a male plug on the end. I have a couple laying around, but not the correct specs.
Specs
INPUT - 200-240v ~ 50/60Hz (0.4A)
OUTPUT - +5V ~ 2.4A
Please help. No network at the moment :mad:
best thing i could recommend is a multi adapter.. Pick & pay or any non computer place .. you can set it to what you want and it has like 4 diffrent heads on... otherwise take the switch to your nerest DIY place and find 1
For some reason, I have never had any luck with the multi-purpose adaptors... will use one only as a last resort. I have found someone that is looking for one with the specs that I need.
Anyone else?
lol...adapter from pick 'n pay...cool for your walkman
but not @ 2.4amps like the poster needs...more like 300ma eh?
good one, had a nice laugh
u were joking, werent you?
Anyone? Getting desperate here, I don't wanna have to get a new switch just because the power adaptor has blown...
The multi-purpose adaptor is 500ma, non selectable.
