Shah33m
hi, all of a sudden my pretec 8gig usb changed to RAW format, i now cannot format it or do anything. any ideas on how to fix it?
Quick format the flash drive then download a trial program called "Recover My Files" or another called "Recuva" then run them on the flash drive to recover anything you might have lost - Saved a friend of mine's life recovering a matric biology project on his flash drive.
Sounds like a lot easier option is to pop out and buy a new one. Not that expensive, really.
Three possibilities using gparted to format/repartition the flash drive:
2. download gparted.iso, create a CD from it, boot from the CD and run gparted on the flash drive.
so ths WILL work? using XP
Yip, you're booting off the CD and running in a linux environment.
i dont know what you mean by it running in a linux environment. anyway will download the app now and do this using xp (i dont have linux)
edit: i downloaded it (1.3mb) it was in rar format so i extracted it and get a whole lota files and folders. what now?
The iso is a mini Linux distro. Restart your pc with the iso burned to cd (and in your cdrom tray). Then go to the gparted program, select the flash drive from the dropdown and delete partition, create new and format it. Then reboot into Windows again.
froot has given you the info. You don't have to know anything about Linux, you end up in a windowed OS with gparted as pretty much the only usable app.i dont know what you mean by it running in a linux environment. anyway will download the app now and do this using xp (i dont have linux)
You should have downloaded an iso file, not a rar file:edit: i downloaded it (1.3mb) it was in rar format so i extracted it and get a whole lota files and folders. what now?
