USB DEVICE NOT RECOGNISED
cryptic1
Esplanade, Durban
Hello chaps :)
I purchased a MS wireless keyboard & mouse last month and after attending to a fresh install and installation of drivers/software for this ****en thing I get that annoying intermittent message 'usb device not recognised'. I attend to a format and re-install and still nothing, also tried the power off and inf. deletion as sourced by google and nada. I now humbly submit myself to your expert opinion/help.
The only option not attempted is the cmos reset.
Thank you in advance.
Ty hashbrown99, yep took out the flippen cmos battery and the message still appears. I feel like putting my fists through the ****en screen. I just give up :(
I would throw the !@#$ external HDD off a cliff if there was one nearby. All my other USB devices work but not this one. Going to waste a day later this week re-installing XP and Windows 7. What gets me is that the thing worked fine for a week but now refuses
Ok, all's well again after a format and re-installation of Vista 64 bit :). The usb device that Win 7 couldn't recognise was actually my Dlink ethernet card. Vista also dloaded drivers for the mobo chipset, etc, etc. So I think I'll stay with Vista for a while, Win 7 freaked me out for the last couple of days.
win7 issue?
I have 2 external drives that gives same issue, can't recognise, so cant use
and its only on windows 7 pcs.
stick it into XP pc works just fine
Disabled one of my USB controllers - had to try them all - and miraculously the drive is visible again.
:confused:
Format and re-install didn't work :mad:
Hey hash, ja that flippen message appeared in Vista. I reverted to Win 7 this weekend and same thing. I read in win 7 forums that 64bit had some issues and the guy installed 32 bit and all was fine. I'm gonna attempt that now and will advise later again. I also read in that forum that someone had luck with copying inf folder to a New folder in windows and getting windows to look in that folder and all was sorted (really how odd). Anyways I'll post should I have any luck in 32bit.
Ok I give up, tried installing 32bit and @ post screen it looked for a driver :( and you know the rest.
Been there done that. I know how you feel
I had issues with 64-bit and 32-bit. Eventually stuck with 32-bit as more of my admittedly ancient hardware works with it and upgrading isn't an option right now
Well you guys are not gonna believe this...BUT IT SEEMS LIKE IT WAS THIS F@$#@##N BITDEFENDER INTERNET SECURITY THAT F@#$%#@D MY SYSTEM UP AND ALMOST MY F@#$%^&N SANITY - DAMMIT
