usermod help
Veroland
South Crest, Alberton
Hi
I have a weird thing here (or it's just me)
I run usermod as root to add a user to groups: #usermod -A uucp,dialout username
Everything is fine even after I close the root session but as soon as my user logs out and in again the group memberships is gone. :confused::confused:
Am I misunderstanding usermod?
You need use the -G (note that -G is case sensitive. -g means something else) option. It'll be something like:
usermod -a -G uucp,dialout username
Group information is strored in /etc/group. So you can just add your user to the last column in the group if you're having problems with usermod.
