Using DDproxy and openrouter
Nick333
Is it possible to use openrouter and DDproxy at the same time?
What I want to do is use openrouter for local downloads and all my browsing and use my prepaid Web Africa account only for playing Guildwars.
Assuming that it is possible would someone be kind enough to explain how I go about setting this up?
Thanks in advance.
you are looking for RouteSentry.
You setup you router in bridge more make two "dialup" connections in windows (one for your openweb account, another for your web africa account) You connect using RouteSentry and it automatically passes traffic to the appropriate account. You can use openrouter on top of this as normal. Since you are connecting to the local openbrowse server, all traffics openrouter generates goes through your local account
Thanks for the help.
I can't get both to connect at the same time though. Its still pretty handy in that I dont have to type in the username and password and reset my modem every time I switch between the two though.
Have you installed RASPPPOE?
To make use of this program you must install the RASPPPOE protocol (see
http://raspppoe.com for more info) on your PC and use it to establish “Dial Up”
style connections for each of your ADSL accounts. Please check the RASPPPOE web
site for details on exactly how to do this.
I created one connection using the normal method and the other using the raspppoe protocol
