Using nftables for blocklists
r00igev@@r
Draadloos Bantha poo doo in 4ways
I'm looking at moving from IPSET to nftables sets for blocklists and not seeing anythiny that fits the bill.
I'm creating my own but its a slow slog (I have a rough one started) and not as easy as the scripts for IPSET.
Anyone have any ideas or sample scripts for this.
You can use the ip set type for IP addresses and inet for IP subnets. For example:
Code:
nft add set ip my_blocklist {
  type ipv4_addr
  elements = { 1.2.3.4, 5.6.7.8, .... }
nftables rules:
Code:
nft add rule ip filter input ip saddr @my_blocklist drop
This rule drops incoming packets from IP addresses in the my_blocklist set.
add IP's to the sets:
Code:
nft add element ip my_blocklist { 9.9.9.9 }
Load nftables rules and make active.
Here we go with my efforts:
/etc/extra-threatblock/extra-threatblock.conf
Code:
BLOCKLIST_NAME=threatblock # Table used within nftables
BLOCKLIST_TMP=${BLOCKLIST_NAME}-tmp
BLOCKLIST_DIR=/etc/extra-threatblock
BLOCKLIST=${BLOCKLIST_DIR}/extra-threatblock.list
LOCAL_BLOCKLIST_EXCEPTIONS=${BLOCKLIST_DIR}/local-${BLOCKLIST_NAME}.exceptions
EXTERNAL_BLOCKLIST_EXCEPTIONS=${BLOCKLIST_DIR}/external-${BLOCKLIST_NAME}.exceptions
NFT_TEMPLATE=${BLOCKLIST_DIR}/nft-blocklist.template # Template file for nftables rules
VERBOSE=yes # Set to no for cron jobs, default to yes
FORCE=yes # Will create the nft table if it does not already exist
OPTIMIZE_CIDR=yes # Optimize block list by aggregating overlapping subnets
# Block policy: 'drop' or 'reject', default: 'drop'
BLOCK_POLICY=drop
# Blocklists of IPs being dropped
BLOCKLISTS=(
    "file:///etc/${BLOCKLIST_DIR}/${BLOCKLIST_NAME}-custom.list" # Optional, for your personal nemeses
    "https://reputation.alienvault.com/reputation.generic" # Alienvault
    "https://iplists.firehol.org/files/talosintel_ipfilter.ipset" # Talos
    "https://iplists.firehol.org/files/tor_exits_7d.ipset" # TOR exit nodes
    "https://cinsscore.com/list/ci-badguys.txt" # C.I. Army Malicious IP List
    "https://lists.blocklist.de/lists/all.txt" # blocklist.de attackers
    "https://rules.emergingthreats.net/fwrules/emerging-Block-IPs.txt" # Emerging threats
    "https://rules.emergingthreats.net/blockrules/compromised-ips.txt" # Emerging threats
    "https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/firehol_level1.netset" # Firehol Level 1
    "https://gitlab.com/ohisee/block-shodan-stretchoid-census/raw/master/pf_table_shadowserver.txt" # Shadow server
    "https://gitlab.com/ohisee/block-shodan-stretchoid-census/raw/master/pf_table_shodan.txt" # Shodan
    "https://gitlab.com/ohisee/block-shodan-stretchoid-census/raw/master/pf_table_sogou.txt" # Sogou search engine
    "https://gitlab.com/ohisee/block-shodan-stretchoid-census/raw/master/pf_table_internet_cens.txt" # Internet census
    "https://gitlab.com/ohisee/block-shodan-stretchoid-census/raw/master/pf_table_diverseenvironment.txt" # Diverse environment
    "https://gitlab.com/ohisee/block-shodan-stretchoid-census/raw/master/pf_table_netsysres.txt" # Net Systems Research
    "https://gitlab.com/ohisee/block-shodan-stretchoid-census/raw/master/pf_table_rwth-aachen.txt" # AAChen
    "https://gitlab.com/ohisee/block-shodan-stretchoid-census/raw/master/pf_table_onyphe.txt" # onephe
    "https://gitlab.com/ohisee/block-shodan-stretchoid-census/raw/master/pf_table_stretchoid.txt" # Strechoid
    "https://gitlab.com/ohisee/block-shodan-stretchoid-census/raw/master/pf_table_openportsstats.txt" # OpenPortStats
    "https://iplists.firehol.org/files/normshield_high_webscan.ipset" # Normshield high risk scanners
    "https://raw.githubusercontent.com/stamparm/ipsum/master/levels/3.txt" # IPSUM
    "https://raw.githubusercontent.com/ipverse/rir-ip/master/country/ru/ipv4-aggregated.txt" #Russia
MAXELEM=131072
/usr/local/sbin/extrathreatblock.sh
Code:
#!/bin/bash
# extra-threatblock: A hack by r00igev@@r
# usage extra-threatblock.sh <configuration file>
# eg: extra-threatblock.sh /etc/extra-threatblock/extra-threatblock.conf
function exists() { command -v "$1" >/dev/null 2>&1 ; }
# Check that configuration file has been specified
if [[ -z "$1" ]]; then
  echo "Error: please specify a configuration file, e.g. $0 /etc/extra-threatblock/extra-threatblock.conf"
  exit 1
fi
# Shellcheck source=extra-threatblock.conf
if ! source "$1"; then
  echo "Error: can't load configuration file $1"
  exit 1
fi
# Check if all commands exist
if ! exists curl && exists egrep && exists grep && exists nft && exists sed && exists sort && exists wc && exists iprange ; then
  echo >&2 "Error: searching PATH fails to find executables among: curl egrep grep nft sed sort wc iprange"
  exit 1
fi
# Check if BLOCK_POLICY is defined
if [ -z "$BLOCK_POLICY" ]; then
  echo "Error: BLOCK_POLICY is not defined. Please set the BLOCK_POLICY variable."
  exit 1
fi
# Do CIDR optimization if set
DO_OPTIMIZE_CIDR=no
if exists iprange && [[ ${OPTIMIZE_CIDR:-yes} != no ]]; then
  DO_OPTIMIZE_CIDR=yes
fi
# Remove comments from exceptions files
if [ -f "$LOCAL_BLOCKLIST_EXCEPTIONS" ]; then
   LOCAL_EXCEPTIONS_TMP=$(mktemp)
   for exception in $(sed -r -e 's/\s*#.*$//;/^$/d' "$LOCAL_BLOCKLIST_EXCEPTIONS")
      do
         exception_array+=( "$exception" )
         echo $exception >> $LOCAL_EXCEPTIONS_TMP
   done
fi
if [ -f "$EXTERNAL_BLOCKLIST_EXCEPTIONS" ]; then
   EXTERNAL_EXCEPTIONS_TMP=$(mktemp)
   for exception in $(sed -r -e 's/\s*#.*$//;/^$/d' "$EXTERNAL_BLOCKLIST_EXCEPTIONS")
      do
         echo $exception >> $EXTERNAL_EXCEPTIONS_TMP
   done
fi
# Create the nftables set if needed (or abort if does not exist and FORCE=no)
# Check if the template file exists
if [ ! -f "$NFT_TEMPLATE" ]; then
  echo "Error: Template file not found at $NFT_TEMPLATE."
  exit 1
fi
# Use the nft command to delete the table
nft delete table inet "$BLOCKLIST_NAME" 2>/dev/null
echo "nftables table '$BLOCKLIST_NAME' dropped."
# Read the template file, replace ${BLOCK_POLICY} with the actual value, and create the nftables table
nft -f <(sed "s/\${BLOCK_POLICY}/$BLOCK_POLICY/g" "$NFT_TEMPLATE")
echo "nftables table '$BLOCKLIST_NAME' created with BLOCK_POLICY=$BLOCK_POLICY."
BLOCKLIST_TMP=$(mktemp)
echo -n "Downloading blacklists:"
for i in "${BLOCKLISTS[@]}"
do
  IP_TMP=$(mktemp)
  (( HTTP_RC=$(curl -L -A "extra-threatblock/script/github" --connect-timeout 10 --max-time 10 -o "$IP_TMP" -s -w "%{http_code}" "$i") ))
  if (( HTTP_RC == 200 || HTTP_RC == 302 || HTTP_RC == 0 )); then # "0" because file:/// returns 000
    command grep -Po '^(?:\d{1,3}\.){3}\d{1,3}(?:/\d{1,2})?' "$IP_TMP" | sed -r 's/^0*([0-9]+)\.0*([0-9]+)\.0*([0-9]+)\.0*([0-9]+)$/\1.\2.\3.\4/' >> "$BLOCKLIST_TMP"
    [[ ${VERBOSE:-yes} == yes ]] && echo -n "."
  elif (( HTTP_RC == 503 )); then
    echo -e "\\nUnavailable (${HTTP_RC}): $i"
  else
    echo >&2 -e "\\nWarning: curl returned HTTP response code $HTTP_RC for URL $i"
  fi
  rm -f "$IP_TMP"
done
# Optimize CIDR
sed -r -e '/^(0\.0\.0\.0|10\.|127\.|172\.1[6-9]\.|172\.2[0-9]\.|172\.3[0-1]\.|192\.168\.|22[4-9]\.|23[0-9]\.)/d' "$BLOCKLIST_TMP"|sort -n|sort -mu >| "$BLOCKLIST"
if [[ ${OPTIMIZE_CIDR} == yes ]]; then
  if [[ ${VERBOSE:-no} == yes ]]; then
    echo -e "\\nAddresses before CIDR optimization: $(wc -l "$BLOCKLIST" | cut -d' ' -f1)"
  fi
  < "$BLOCKLIST" iprange --optimize - > "$BLOCKLIST_TMP" 2>/dev/null
  if [[ ${#exception_array[@]} > 0 ]]; then
    echo "Allowing for ${#exception_array[@]} exclusions from threatblock"
    echo "Addresses before removing exclusions: $(wc -l "$BLOCKLIST_TMP" | cut -d' ' -f1)"
    BLOCKLIST_WITH_EXCEPT_TMP=$(mktemp)
    iprange "$BLOCKLIST_TMP" --except "$EXTERNAL_EXCEPTIONS_TMP" > "$BLOCKLIST_WITH_EXCEPT_TMP" 2>/dev/null
    cp "$BLOCKLIST_WITH_EXCEPT_TMP" "$BLOCKLIST_TMP"
  fi
    echo "Addresses after CIDR optimization:  $(wc -l "$BLOCKLIST_TMP" | cut -d' ' -f1)"
  fi
  cp "$BLOCKLIST_TMP" "$BLOCKLIST"
fi
rm -f "$BLOCKLIST_TMP"
echo -n "Populating nft threatblock:"
# Define the name of the set and the filename containing IPs/subnets
set_name="hexceptions-v4"
blocklist_file="$LOCAL_EXCEPTIONS_TMP"
# Read the internal exceptions file line by line
while IFS= read -r line; do
  # Add the IP/subnet to the nftables set 2>/dev/null
  nft add element inet threatblock "$set_name" { $line }
  # Increment the count
done < "$blocklist_file"
set_name="blocklist-v4"
blocklist_file="$BLOCKLIST"
# Count for printing dots
count=0
# Number of IPs to add in each batch
batch_size=256
# Initialize a string to store IPs with commas
ip_batch=""
# Read the blocklist file line by line
  # Add the IP to the batch with a comma separator
  if [ -z "$ip_batch" ]; then
    ip_batch="$line"
  else
    ip_batch="$ip_batch,$line"
  fi
  # If the batch size is reached, add IPs and print a dot
  if (( count % batch_size == batch_size - 1 )); then
    nft add element inet threatblock "$set_name" { $ip_batch } 2>/dev/null
    ((count += 1))
    echo -n "."
    ip_batch="" # Clear the batch
  fi
  ((count++))
# Add any remaining IPs in the last batch
if [ -n "$ip_batch" ]; then
  ((count++))
  echo -n "."
fi
# Print a newline after all IPs have been processed
echo
   echo
   echo "Threatblock completed. $count IPs/subnets added to $set_name."
fi
/etc/extra-threatblock/local-threatblock.exceptions
Code:
127.0.0.0/8
100.64.0.0/10
192.168.0.0/16
172.16.0.0/12
10.0.0.0/8
240.0.0.0/4
224.0.0.0/4
/etc/extra-threatblock/external-threatblock.exceptions
Code:
100.64.0.0/10
1.1.1.0/24
Fixed some things in /etc/extra-threatblock/extra-threatblock.conf
If you have /etc/extra-threatblock/threatblock-custom.list it will add the IPs in there to the blocklist. Try
Code:
8.8.8.8
8.8.4.4
Code:
BLOCK_POLICY=drop
BLOCKLISTS=(
    "file://${BLOCKLIST_DIR}/${BLOCKLIST_NAME}-custom.list" # Optional, for your personal nemeses
    "https://raw.githubusercontent.com/ipverse/rir-ip/master/country/ru/ipv4-aggregated.txt" # Russia se push
MAXELEM=131072
And some tweaks on /usr/local/sbin/extrathreatblock.sh
Code:
#!/bin/bash
# Extra Threatblock: A threat intelligence script by r00igev@@r/mybroadband
  exit 1
fi
  exit 1
fi
if ! exists curl && exists egrep && exists grep && exists nft && exists sed && exists sort && exists wc && exists iprange && figlet ; then
  echo >&2 "Error: searching PATH fails to find executables among: curl egrep grep nft sed sort wc iprange figlet"
  exit 1
fi
figlet -f slant Extra Threatblock
echo "Extra enabled gateway. Driving SD-WAN adoption in South Africa! https://fusionsdwan.co.za"
  exit 1
fi
DO_OPTIMIZE_CIDR=no
fi
      do
   done
fi
      do
   done
fi
  exit 1
fi
do
  IP_TMP=$(mktemp)
  (( HTTP_RC=$(curl -L -A "extra-threatblock/script/mybroadband" --connect-timeout 10 --max-time 10 -o "$IP_TMP" -s -w "%{http_code}" "$i") ))
  else
  fi
  rm -f "$IP_TMP"
done
# Optimize CIDR
  fi
  fi
  fi
fi
count=0
# Number of IPs to add in each batch - too big and nft will not load it
batch_size=256
ip_batch=""
    ip_batch="$line"
  else
  fi
    ((count += 1))
    echo -n "."
  fi
  ((count++))
  ((count++))
  echo -n "."
fi
echo
fi
Why dont you use / install firehol and its Lists
Install the package firehol-tools and then run and get familiar the update-ipsets
Else look at CSF or crowdsec
Hope you come right
Hope you come right
I wanted to move away from iptables and ipset as that is being depreciated.
My script is now running like a train using nft sets and the performance is great.
I can also tweak things easily.
PS: I am using some of the lists from firehol if you look at the .conf file.
Here is /etc/extra-threatblock/nft-blocklist.template
Code:
table inet threatblock {
        set hexceptions-v4 {
                type ipv4_addr
                flags interval
                auto-merge
        set hexceptions-v6 {
                type ipv6_addr
                flags interval
                auto-merge
        set blocklist-v4 {
                type ipv4_addr
                flags interval
                auto-merge
        set blocklist-v6 {
                type ipv6_addr
                flags interval
                auto-merge
        chain forward {
                type filter hook forward priority -1; policy accept;
                iifname lo accept
                ct state established,related accept
                ip daddr @blocklist-v4 counter ${BLOCK_POLICY}
                ip6 daddr @blocklist-v6 counter ${BLOCK_POLICY}
                ip saddr @blocklist-v4 counter ${BLOCK_POLICY}
                ip6 saddr @blocklist-v6 counter ${BLOCK_POLICY}
                counter
        chain input {
                type filter hook input priority -1; policy accept;
                iifname lo accept
                ip saddr @hexceptions-v4 counter accept
                ip6 saddr @hexceptions-v6 counter accept
                counter
        chain output {
                type filter hook output priority -1; policy accept;
                iifname lo accept
                counter
Another some more small tweaks. Added Nigeria to join Russia se push.
Increased the batch size up to 512 which seems to work well. (Don't try and add a nft set of 50k in one load).
Added an extra rule to drop any remote IP that scans or accesses a set of 10 canary ports for 24 hours. That is a sort of second layer threatblock that targets those not in the threat intelligence feeds but still up to no good. As an example, anyone who attempts a telnet will have all their packets dropped for 24 hours.
Still need to fix the ipv6 parts.
Here is the latest /etc/extra-threatblock/nft-blocklist.template
Code:
        set canary_ports {
                type inet_service
                elements = { 23, 25, 110, 139, 445, 3389, 5900, 7547, 8291, 8080 }
        set trap {
                type ipv4_addr
                flags dynamic, timeout
                timeout 24h
                type ipv4_addr
                flags interval
                auto-merge
                type ipv6_addr
                flags interval
                auto-merge
        set blocklist-v4 {
                type ipv4_addr
                flags interval
                auto-merge
        set blocklist-v6 {
                type ipv6_addr
                flags interval
                auto-merge
        chain forward {
                iifname lo accept
                counter
        chain input {
                iifname lo accept
                tcp dport @canary_ports add @trap { ip saddr }
                ip saddr @trap drop
                counter
        chain output {
                iifname lo accept
                counter
Here is the latest /etc/extra-threatblock/extra-threatblock.conf
Code:
BLOCK_POLICY=drop
BLOCKLISTS=(
    "https://raw.githubusercontent.com/ipverse/rir-ip/master/country/ng/ipv4-aggregated.txt" # Nigeria se push
MAXELEM=131072
Mod to specify the WAN interface when there is a LAN or VPN interface. The Canary ports are only triggered on the WAN.
Code:
#!/bin/bash
# Version 0.0.2 October 2023
PATH=/usr/sbin:/usr/local/bin:/usr/bin:/bin:
  exit 1
fi
  exit 1
fi
  exit 1
fi
  exit 1
fi
# Check if WAN_IF is defined
if [ -z "$WAN_IF" ]; then
  echo "Error: WAN_IF is not defined. Please set the WAN_IF variable."
  exit 1
fi
DO_OPTIMIZE_CIDR=no
fi
if [ -f "$INTERNAL_BLOCKLIST_EXCEPTIONS" ]; then
   INTERNAL_EXCEPTIONS_TMP=$(mktemp)
   for exception in $(sed -r -e 's/\s*#.*$//;/^$/d' "$INTERNAL_BLOCKLIST_EXCEPTIONS")
      do
         echo $exception >> $INTERNAL_EXCEPTIONS_TMP
   done
fi
      do
   done
fi
  exit 1
fi
# Read the template file, replaces ${WAN_IF} and ${BLOCK_POLICY} with the actual values, and create the nftables table
nft -f <(sed -e "s/\${BLOCK_POLICY}/$BLOCK_POLICY/g" -e "s/\${WAN_IF}/$WAN_IF/g" "$NFT_TEMPLATE")
echo "nftables table '$BLOCKLIST_NAME' created with with WAN interface $WAN_IF and block policy $BLOCK_POLICY."
do
  IP_TMP=$(mktemp)
  else
  fi
  rm -f "$IP_TMP"
done
# Optimize CIDR
  fi
  fi
  fi
fi
blocklist_file="$EXTERNAL_EXCEPTIONS_TMP"
set_name="iexceptions-v4"
blocklist_file="$INTERNAL_EXCEPTIONS_TMP"
count=0
batch_size=512
ip_batch=""
    ip_batch="$line"
  else
  fi
    ((count += 1))
    echo -n "."
  fi
  ((count++))
  ((count++))
  echo -n "."
fi
echo
fi
Code:
INTERNAL_BLOCKLIST_EXCEPTIONS=${BLOCKLIST_DIR}/internal-${BLOCKLIST_NAME}.exceptions
BLOCK_POLICY=drop
# WAN interface
WAN_IF=ens18
# LAN interface
LAN_IF=ens18
BLOCKLISTS=(
MAXELEM=131072
and the template
Code:
        set canary_ports {
                type inet_service
                elements = { 23, 25, 110, 139, 445, 554, 1080, 3389, 5900, 7547, 8291, 8080, 31337 }
        set trap {
                type ipv4_addr
                timeout 8h
                type ipv4_addr
                flags interval
                auto-merge
                type ipv6_addr
                flags interval
                auto-merge
        set iexceptions-v4 {
                type ipv4_addr
                flags interval
                auto-merge
        set iexceptions-v6 {
                type ipv6_addr
                flags interval
                auto-merge
        set blocklist-v4 {
                type ipv4_addr
                flags interval
                auto-merge
        set blocklist-v6 {
                type ipv6_addr
                flags interval
                auto-merge
        chain forward {
                iifname lo accept
                counter
        chain input {
                iifname lo accept
                iifname ${WAN_IF} tcp dport @canary_ports add @trap { ip saddr }
                ip saddr @trap drop
                counter
        chain output {
                iifname lo accept
                counter
The results look very good. The canary ports wipe out many IPs as do the aggregated blocklist. sshguard only has to deal with very few attacks, spaced about 4 hours apart.
Here is the rap trap. Its large:
The blocklist is also working but there was no one using this gateway between midnight and now. So stats are low. Will show the counters this evening.
So I have added a few extra small notifications (using ntfy.sh where I have an account - great app!!!)
It will notify you every time some logs in via either ssh or the console. It will tell you when the IP is not in sshguard's whitelist.
You need to install grepcidr and neoftech
/etc/profile.d/extra.sh
Code:
#!/bin/bash
echo "Extra enabled gateway. Driving SD-WAN adoption in South Africa!"
# Use the 'who' command to find the current user's session and extract the remote host
user_session=$(who -m | awk -v user="$(whoami)" '$1 == user {print $5}' | sed 's/[()]//g')
found=false
tempwhitelist=$(mktemp) || { echo "Failed to create temporary whitelist"; exit 1; }
# Use grep to filter lines and save to the temporary file
grep -E '^[#[:space:]]*[^[:alpha:]]*$' /etc/sshguard/whitelist > "$tempwhitelist"
# Check if a user session was found that is not a login via SSH directly
if [ ! -n "$user_session" ]; then
  note=`/usr/bin/neofetch --stdout`
  curl -s -o /dev/null \
    -H "Authorization: Bearer <key>" \
    -H prio:high \
    -H tags:policeman \
    -d "TTYD login for ${PAM_RHOST} $note" \
    ntfy.sh/<channel>
    found=true
  else
  while read -r subnet; do
    if grepcidr "$subnet" <<< "$user_session"; then
      found=true
      break
    fi
  done < "$tempwhitelist"
fi
neofetch --ascii "$(figlet -f slant fb)"
if [ "$found" = false ]; then
    -H prio:high \
    -H tags:ghost \
    -d "!!!!! ALERT Login not whitelisted for ${user_session} !!!!!" \
    ntfy.sh/<channel>
fi
Add this to /etc/pam.d/sshd
Code:
# Login notification
session optional pam_exec.so /usr/local/sbin/ntfy-ssh-login.sh
Code:
#!/bin/bash
if [ "${PAM_TYPE}" = "open_session" ]; then
  curl \
    -H prio:high \
    -H tags:policeman \
    -d "SSH login on ${HOSTNAME}: ${PAM_USER} from ${PAM_RHOST} $note" \
    ntfy.sh/<channel>
fi
sudo chmod +x /usr/local/sbin/ntfy-ssh-login.sh
sudo chmod +x /etc/profile.d/extra.sh
