clasqm
OK, I am going to buy a Mac Mini. But not the regular one: I want the one with a terabyte of storage and no optical drive. On the rare occasion that I need to read a CD or DVD I can always plug in a USB drive.
Here's the catch: the Mini Server ships with OSX Snow Leopard Server, which I've never worked with. And apparently you can't put regular Snow Leopard on it because the graphics h/w needs different drivers. The questions are:
1. Can I ignore the server stuff and just run SL Server as a general-purpose OS?
2. Will SL Server run mac OSX software with compatibility, let's say, back to Leopard? For example, could I grab iLife 06 from my old Leopard install disks and have it work? (Yes, I am cheap, but I don't see anything Apple has done to iLife since then to be an improvement. YMMV)
I imagine that there could be systems utilities that "hook" deep into the OS that won't work. But as far as I can tell, anything that doesn't require a system password to install should be OK?
If you have experience working with this version of OSX, I'd appreciate your thoughts.
