Challenged
- Nov 9, 2006
Morning all,
I am trying to setup the utTracestar app on a Win2k with iburst USB modem (black) and I run the setup wizard and the below error message occurs...
I hit continue and I am then prompted to select an ethernet adapter, but none are found - I am using black USB should this not be the case?? and the application crashes.
Also, why must I assign a static IP address eg (address ip to 192.168.250.1 subnet to 255.255.255.0), when my IP addresses are (apprently) assigned dynamically by iBurst - surely this leads to congestion through the network?
thx
******* error message *******
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Management.ManagementException: Invalid query
at System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode)
at System.Management.ManagementObjectEnumerator.MoveNext()
at System.Management.ManagementObjectCollection.get_Count()
at g.c(Object A_0, EventArgs A_1)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///d:/winnt/microsoft.net/framework/v1.1.4322/mscorlib.dll
utTraceStar
Assembly Version: 1.0.13.29852
Win32 Version: 1.0.13.29852
CodeBase: file:///L:/Downloadz%20Folder/Downloads/Internet%20Software/utTraceStarv1p0p13/utTraceStar/utTraceStar.exe
CodeBase: file:///d:/winnt/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///d:/winnt/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///d:/winnt/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Accessibility
Win32 Version: 1.1.4322.573
CodeBase: file:///d:/winnt/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
System.Management
CodeBase: file:///d:/winnt/assembly/gac/system.management/1.0.5000.0__b03f5f7f11d50a3a/system.management.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
thx
mscorlib
utTraceStar
System
System.Drawing
Accessibility
System.Management
enabled.
For example:
<configuration>
</configuration>
