Using VOIP with local numbers
Vikki Sixx
Hi All,
Can someone explain how to make local calls from your PC to local 0860 numbers? I have Vopi Stunt which I use very successfully to dial people overseas, but I have no idea how to dial the 0860 numbers, and also to enter options " dial 1 for sales" either ....
any ideas?
Vic
Where are you based? In South Africa?
To select options from an IVR you must have the right DTMF signalling solution. I mostly use SIP info. If that doesn't work try RFC2833. Inband doesn't work on IP solutions so that might be your problem.
Hi There,
I am using 3CX and I can dial any number and it connects. it is also sending the DTMF using RFC833 works fine.
Regards
Tim
