Interesting... "the rest" is enabled and working perfectly for me.
Are you able to plug more than one device into your ONT?Interesting... "the rest" is enabled and working perfectly for me.
I find that I can use any ONE of the ports, not more than one port.
Would all the ports be on the same vlan? In which case all your broadcast traffic on your line goes up your fibre as well - not sure that's a good thing?All the ports are also enabled on mine (Lights go on on every port I plug something in) The ports that are not configured could possible work like normal switch ports then (I have never tried)
So the two devices with private IP's could probably see each other but will have no internet access as that has to go through your router.... or do you have a 2nd cable running from a lan port on your router to another open port on the ONT?
I wonder if you'd also capture broadcast traffic from the ISP vlan on your local machines as well...
I'm going to test this today, to see out of interest what's happening on that ONT. Purely for switch port purposes, not for internet access directly.If he says it's working (would love to know if he has internet access on the two with private IP's though) then it must be all in the same vlan, probably default untagged vlan 1 for all the non configured ports. Not sure if they actually change the VLAN on the configured port 1.
Either way, the two with pc's/devices he did plug in there that is "working" can't have internet access that way, unless there is another cable running from the lan port on his router to another open port on the ONT.
But ja, would not recommend using that as another switch at all even if it's working....
I can use any of the ports, doesn't have to be port 1, but can only use one at a time.you are right, only 1 port will be enabled and it's usually locked to a specific isp. The model is very different to Openserve fibre where you can use multiple isps
