Hi can someone please help me out.
I have a form with 2 lables (Username, Password) and 2 textbox (textbox1, textbox2) and a OK btn and cancel btn
The program has been done with datasets coz I'm not a pro in programming
I need to validate a user to get access to the database coz it's confidential info and I would like to give some users more access then others. If you have that login form how do I go about this?
Ok this is what I've got for now:
Imports System.Windows.Forms
Imports System.Security.Cryptography
Public Class LoginForm1
Private Sub OK_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles OK.Click
Me.DialogResult = System.Windows.Forms.DialogResult.OK
Me.Close()
End Sub
Private Sub Cancel_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Cancel.Click
Me.DialogResult = System.Windows.Forms.DialogResult.Cancel
Me.Close()
End Sub
Private Sub LoginForm1_FormClosing(ByVal sender As System.Object, ByVal e As System.Windows.Forms.FormClosingEventArgs) Handles MyBase.FormClosing
If TextBox2.Text.Length = 0 Then
MsgBox("Please enter a password.", MsgBoxStyle.Exclamation, "Password Required")
e.Cancel = True
Return
End If
Dim Username, Password, PasswordHash As String
Dim UserPass As String
UserPass = Me.TBDataSet.Users.PasswordColumn.ColumnName
If Me.DialogResult = Windows.Forms.DialogResult.OK Then
Username = TextBox1.Text
Password = TextBox2.Text
PasswordHash = HashString(Password)
If Userpass = PasswordHash Then
MsgBox("Yes", MsgBoxStyle.OkOnly)
Else
MsgBox("No", MsgBoxStyle.OkOnly)
End If
End If
End Sub
Private Function HashString(ByVal input As String)
'compute the hash value of the password
Dim bytes = System.Text.Encoding.UTF8.GetBytes(input)
Dim hashBytes As Byte()
Dim md5Provider = MD5.Create()
hashBytes = md5Provider.ComputeHash(bytes)
Dim sb As New System.Text.StringBuilder
Dim b As Byte
For Each b In hashBytes
sb.Append(b.ToString("x2"))
Next
Return sb.ToString()
End Function
End Class
Ok, Think the problem is with my IF statement. I don't think this:
is working lekker, lol...
Any ideas? I'm comparing the Login with a Table in SQL (The table has Username, Password as fields)
Me.Close()
End Sub
Me.Close()
End Sub
e.Cancel = True
Return
End If
Else
End If
End If
End Sub
Dim b As Byte
Next
End Function
End Class
