I finally got my adsl line upgraded to vdsl. I am about 1 km from a newly installed msan box. Do I need to log a fault regarding the FEC issues ? Also should i be able to push the download speed higher ?
Modulation type G.993.2-B
Actual rate (up) 3072 kbps
Actual rate (down) 26748 kbps
Data transfered (sent) 0 kB
Data transfered (received) 0 kB
Output power (up) 12.8 dBm
Output power (downstream) 7.4 dBm
Line attenuation (up) 0 dBm
Line attenuation (downstream) 26.7 dB
Noise margin (up) 12.6 dB
Noise margin (downstream) 6 dB
Manufacturer ID (local) IFTN
Manufacturer ID (remote) BDCM
Loss of frames (local) 0
Loss of frames (remote) 0
Error seconds (local) 8
Error seconds (remote) 0
FEC Errors (up) 0
FEC Errors (down) 423259
CRC Errors (up) 271
CRC Errors (down) 38
HEC Errors (up) 0
HEC Errors (down) 0
FEC Errors (up) 0
CRC Errors (up) 271
HEC Errors (up) 0
HEC Errors (down) 0
