Verbatim flash disk 16gb not working
tcofran
Pretoria
Ola MyBB.
I found this in a drawer this weekend.
When i plug it in Win7 says it's installing drivers, but then after that.... nothing. it doesn't show up in explorer. any ideas from the Mybb boffins to maybe get this going will be appreciated. or maybe it's just dead
Cheers
T
Right click on your Computer Icon and lick on Manage, then once you're in the console goto Disk Management, if the driver installed properly you should see the disk listed in there (it should be the only 16gb drive on the system) if it's there assign it a drive letter by right clicking on it or if it's not there, check the device manager to see if there was an issue with the drivers.
Hi, this is what i get when following your advice, when i remove it, the media part goes away though
