Vesa Wall Mount for Samsung Syncmater 2333
The-Man
(noun) Ones place of existance
Good morning all
I'm looking for a Vesa Wall Mount for a Samsung Syncmater 2333, are there any available for this model if so please tell me which one is the best :D
Vesa complaint monitors and the vesa wall mounts are all standard so you just need the size of the mount ie 75x75 or 100x100. Just google Aavara mounts, they are all vesa spec mounts. The type of mount you want will depend on what you want it to do and/or how much you want to pay as some can get expensive. I know Landmark PC sells them and a few other places but cant remember.
Hope it helps
Hope it helps
Thanks for your help, I Google'd Aavara mounts but couldn't find an extendable swivel arm. Would these be any good? : http://www.amazon.com/VideoSecu-Art...-Pattern/dp/0972683275/ref=dp_cp_ob_e_title_0
or
http://www.amazon.com/Cheetah-Mounts-ALAMLB-Bracket-Articulating/dp/B001GTT0VO/ref=lh_ni_t
Those will work but its huge, here it is locally Landmarkpc just make sure the mount can support the monitor you want to use
