I hooked up my xbox direct to lcd monitor this weekend, HD gaming, the way to go, huge detail difference.
Purchased the HD VGA cable from gamers exchange in Edenvale(its R240).
Re the Audio, I wanted to use the screen built in speakers - so this was a bit of a mission - what you need bascially is an RCA to 3.5 sound card converter - and I searched Makro, Dion wired and Hi Fi corp, and none had.
Spoke to about 3 floor people at Hi-Fi and the one dude was adament they had nothing and that I should get one made up.
Anyhow he was wrong - I went to their PC cable section as they didn't have what I needed in the audio section - what I got there was RCA to 3.5 plug (sound card) as it was male RCA's (R39) (female would have been better) I then got from their audio section RCA coupling (R9) - basically it lets you join an RCA male from each side.
Here is what I find the strange part- yet maybe its not because I am a bit of a technophobe, anyhow I connected the red RCA sound to the Red and the white to the white - seems logical, yet no sound.
For a brief second I thought the dude form hi-fi corp was right, but realising this is almost impossible, I pulled out one of the cables and plugged in the yellow video cable to either the red or white , and presto Houston, we have sound.
There is a button on the cable that you select either VGA or RCA and I think when you select VGA it also changes maybe how the RCA cables function, because there is no logical explanation I can find for the yellow video to now be the audio cable, but it all works and a lot cheaper than a HD TV!!
