Video conversion settings for HD Ready TV
KSINGH
PTA
Hi,
I have the D Series 51" HD ready Plasma and want to convert my DVD collection to play them of my external hard drive.
Which format should I use e.g. AVI, MP4 etc?
What other settings like resolution and audio bit rates should I choose?
Hi,
You will lose quality. Rather just rip them without converting.
I recommend ripping to MKV using Handbrake. You can just set the quality setting high - you won't notice much of a difference between a good rip and direct copy but you will save yourself a lot of hard drive space. Ripping and encoding can be time consuming though if you don't have a beefy enough processor.
Ok thanks guys.I may end up using about 4 laptops to rip if it is time consuming maybe over the weekend.
I used to keep all my DVDs as raw VOBs... but now with Handbrake, you can compress a typical DVD movie to MKV (H.264) with a size of about 2GB (including original audio).
For some reason handbrake did not scan Aliens successfully. I used Aiseesoft. Mkv settings: mp4, aac5.1 and the rest at max. Will check size now. Should I use H.264?
Ok, size is 4.46GB. Also divx could not play the file.
Yes. Use H.264
