Is it a de-colon-ised issue?
Using IE? Getting the same on IE the past few days.
Close and open IE again fixes it temporarily.
Nope reset browser IE and still not working
:erm: at the risk of pointing out the freaking big elephant in the room, use IE to download a better browser.
What would you suggest
What to download if Chrome and FireFox are already being used for other tasks and each signed into thier own separate Gmail accounts?
That is an easy one to answer:
you could install the Chromium browser
you can also be signed into and switch between tabs with more than one Google account in the same browser window
you could go Incognito / Private Window
there are other options like Opera and whatnot
if you really must, try Edge (I haven't and don't intend to).
Thank you it works with Edge
